Yamaha RX-V2500 / sibling models cooling fan behavior?
Discussion in 'AV Receivers & Amplifiers' started by Zacabeb, Jan 11, 2005.
Tags:
  1. Zacabeb
    Zacabeb
    Jan 17, 2002
    474
    +9
    I'm worried that something isn't right with my RX-V2500, because the fan does not spin even when I set it to "continuous" mode (it's among the options where you also set speaker impedance).
    The manual says that the fan will spin continuously in this mode regardless of temperature, giving the impression it would start spinning as soon as you turn on the receiver. What I'm wondering is if what the option really does is keep the fan spinning only after the receiver gets hot enough to turn it on, whereas in the "auto" mode it would turn off again after the receiver cooled down. I'm not sure about this, and Yamaha Scandinavia haven't been able to help much as they weren't even aware the RX-V2500 had a cooling fan in the first place. :rolleyes:
    Is this behavior normal for the cooling fan and do the other related models (RX-V1500, 2400 and 1400) behave the same way?
    The fan itself does work, I've tested it in the diagnostics menu and it spins fine then, so it's not broken or obstructed in any way.
  2. pragmatic
    pragmatic
    Nov 9, 2004
    12,120
    +1,678
    My 2500 fan hasn't come on yet and it gets a bit hot. I'm sure if there was a problem the unit would shut down as thats how they are designed.
    Whats continueous mode, i haven't read the manual yet as yamaha make really bad manuals and remotes, but the amp is great and thats what counts.
  3. Dfour
    Dfour
    Jan 19, 2004
    3,998
    71
    Bracknell
    +85
    I have never found a fan on the 1400.
  4. Zacabeb
    Zacabeb
    Jan 17, 2002
    474
    +9
    The fan is located between the power transformer and the heatsinks. It sucks in air from the grille on the left, through the clear plastic cover around the power transformer, and blows it through the heatsinks to a duct at the other end, which redirects the flow up and out through the upper grille. When forcing it to spin in the diagnostics mode, it cools down the amp very quickly but naturally also makes some noise. I guess for that reason they keep it off unless when it's absolutely needed.
    The continuous mode is set by keeping the STRAIGHT/EFFECT button on the receiver pressed while turning it on, which puts you in the same menu where you select the speaker impedance. Turning the program knob there reveals other options, including toggling the fan mode between "AUTO" or "CONT.". There seems to be no difference between those modes, which is what puzzles me.
  5. Vodder
    Vodder
    Jan 11, 2004
    443
    16
    London, UK
    Can't say I've ever heard the fan come on with my 1400 and it's had some serious seshions, wish the same could be said for my PCs!!
  6. Cimba
    Cimba
    Are there any news because i've the same problem with my 2500.
    How can i test the fan in the diagnostic mode? I have the Pronto and the IR-Code for this, but wasen't in there and before i kill him with this.
    Is there maybe a documantation for this mode?
  7. Markie Boy
    Markie Boy
    Dec 13, 2002
    1,257
    63
    Perth, Western Australia (Originally Ireland)
    +228
    Cimba - Who are what do you want to kill?
  8. Cimba
    Cimba
    I don't know, what options are possible in the diagnostic menu, at TV service menus, it is for example sometimes possible to kill the device with invalid values.
