Yamaha RX-V2500 and MJ Acoustics Pro 50 Subwoofer
Discussion in 'AV Receivers & Amplifiers' started by radicalrad, Jun 1, 2005.
Tags:
  1. radicalrad
    radicalrad
    could someone help me out here please i have just bought this sub for my system and to be honest the manual stinks can someone explain how i should be connecting this to my yamaha is the single phone alright or should i use the "Neutrik cable ?" or both..thanks for any help..
  2. pragmatic
    pragmatic
    Nov 9, 2004
    12,120
    +1,678
    I just use a single phono cable and that works fine.
  3. radicalrad
    radicalrad
    thanks for that i have talked to MJ acoustics now and they say just use the phono as the other on is for if you dont have a sub out on the amp...
    thanks again
  4. pragmatic
    pragmatic
    Nov 9, 2004
    12,120
    +1,678
    There is a sub out on the amp, its beside the pre-outs, I believe its at the bottom of them.
  5. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    The neutrik connection is for high-level/speaker-level, i.e. it allows to connect directly to the speaker terminal of an amp (stereo amps for example don't typically have a subwoofer output).
    For connecting active subs to AV amps/receivers use the line-level connection (phono/RCA connectors).
