Yamaha RX-V1500
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by PerpetualOmega, Dec 5, 2004.
  1. PerpetualOmega
    PerpetualOmega
    Dec 5, 2004
    12
    I have a question regarding the Yamaha RX-V1500.
    Could someone please tell me if it is possible to set the audio levels to each source seperately. I often find myself nearly blowing the speakers moving from DVD to Radio as i forget to change the volume. I used to have a JVC 888RK which set levels indepenently and as the JVC was only a cheap amp i was expecting to find this on the Yamaha, but not yet.
    Many thanks for your time and help
    PerpetualOmega
  2. tecman
    tecman
    I think you are out of luck here, I believe the only non high end products that offer this are the Harmon Kardon range of AV recievers.
