Yamaha RX-V1500; RX-V2500 or DSP-AX750SE?
Discussion in 'AV Receivers & Amplifiers' started by obow, Oct 18, 2004.
Tags:
  1. obow
    obow
    Newly registered but need some advice. I have slowly been building up my Home Cinema Kit, and have narrowed down my choice of amp to one of three:
    1. Yamaha RX-V1500
    2. Yamaha RX-V2500
    3. Yamaha DSP-AX750SE
    There is also the possibility of the RX-V1400/2400 as they are seriously reduced in price, but also becoming quite scarce stock wise, hence my choice of three above.
    My question is has any one got the new 1500/2500, and if so what are there thoughts/experiences? Also, are these worth getting versus the 750 which cheapest I have seen is £359?
    I have seen a couple of reviews of the 1500 so far (What Hi Fi; Home Cinema) and they were both good, but would like more.
    Peter
  2. AndoverRed
    AndoverRed
    Sep 24, 2004
    248
    Andover
    +5
    Peter,
    I can only speak for the Yamaha RX-V2400. I have tested this against the Denon 3805 recently and I preferred the POWER of the 2400 for movies. This can be purchased for £699 now.
    The new RX-V2500 will be a penny under £1000 @AVLAND. Is it worth the extra £300? Difficult to tell at this stage. It boasts a little more power and pure direct for 2-channel. Check the link below for a detailed comparison.
    http://www.audioholics.com/cedia/cedia2004/yamahaRX-V2500receiver.php
    If it delivers more than the RX-V2400 it will give the Denon, Pioneer, and perhaps Arcam a run for their money.
    Regards
    Mark
  3. CosmicOne
    CosmicOne
    The main difference would be the Pure Direct Mode which i had in my RXV650 & it sounds pretty good for stereo & it's not available on 1400/2400,
    so my recommendetion if u aren't gonna need the power of the 1500/2500 (not gonna use in a very large room) so the AX750SE will do u just fine,coz it has nearly all the feaures of the 1500/2500 & much much cheaper.
  4. sharper
    sharper
    Jul 24, 2002
    588
    SW London
    +11
    I think "Pure Direct Mode" = "Direct Stereo" on the 1400 & 2400 :lesson:
  5. Dfour
    Dfour
    Jan 19, 2004
    3,998
    71
    Bracknell
    +85
    I think Yamaha have improved it on the x50 models by switching off the dsp and video channels where as in the x400 series it just bypasses them. Still sounds good though:smashin:
    The advantage that the x400 series have is the extra power they can deliver to the amps so the machine can be driven harder for longer without running out of steam and they are also THX select. They also look better:D IMHO the x50 series look like they fell out of the ugly tree and hit a few branches on the way down :rotfl:
  6. CosmicOne
    CosmicOne
    sharper;
    as "Dfour" said there's a difference between the PureDirectMode & the Direct mode on the 1400/2400.
    Dfour
    man LOL,do u know that i really hate the looks of the 1400/2400 & very much likes the looks of the new 650/750 (not the 350/450) LOL.really its matter of taste.
  7. Dfour
    Dfour
    Jan 19, 2004
    3,998
    71
    Bracknell
    +85
    :offtopic:
    I prefere the clean lines and lack of butons on the 1400 with all the inputs under the flap out of sight. I feel the x50 series fronts look crwoded and busy. As you said its all a matter of taste:D
