Yamaha rx-v1500 error
Discussion in 'AV Receivers & Amplifiers' started by bluebearuk, Mar 9, 2005.
Tags:
  1. bluebearuk
    bluebearuk
    Feb 6, 2005
    13
    When using auto setup on a yamaha rx-v1500, one of the speakers gets REV against it. Does anyone know what this means?
    Steven
  2. Zacabeb
    Zacabeb
    Jan 17, 2002
    474
    +9
    It means that the receiver has detected the speaker as being wired with the incorrect polarity. Check that the polarity is correct at both ends for that speaker. Do not forget to turn the receiver off if you find you have to swap the wires! It's easy to forget.
    The receiver may mistakingly detect the speaker as being wired incorrectly though, so if you find that the speaker is connected right, you can ignore the warning and proceed with the setup.
