Yamaha RX V1500 and 5.1 speaker connections
Discussion in 'AV Receivers & Amplifiers' started by Passingbat, May 12, 2005.
Tags:
  1. Passingbat
    Passingbat
    Feb 20, 2003
    7,569
    UK
    +1,331
    Hi, sorry if this is a dumb question. I'm taking delivery tomorrow of my first home cinema system, so am new to it. I'm getting the Yamaha RX V1500 and Mordaunt Short Avant Premiere Plus speakers.
    I'd just like to check that I'm right in thinking the rear speakers of the Premiere Plus connect to the 'Surround left' and 'Surround Right' NOT the 'Surround Back Left' and Surround Back right'.
    Also, the Mordant short spec. says the impedance is 4-8 ohms. Do I leave the Yamaha set at 8 ohms (rather than changing it to the 6 ohm setting).
    Thanks in advance for any advice.
  2. Damnyoureyes
    Damnyoureyes
    Jun 17, 2004
    46
    Yes put them on the surround left and right ones for 5.1.
    Not sure with the speaker impedance one.
  3. Passingbat
    Passingbat
    Feb 20, 2003
    7,569
    UK
    +1,331
    Thanks for the quick reply, very much appreciated.
  4. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    Just leave it on 8 ohms. You should be fine.
  5. Passingbat
    Passingbat
    Feb 20, 2003
    7,569
    UK
    +1,331
    Thanks for the reply Dfour, very much appreciated. The kit arrived a couple of hours ago --- unfortunately I'm not going to be able to get it set up until Monday ----- gonna be a long three days!
  6. doctorjuggles
    doctorjuggles
    Aug 31, 2004
    799
    London
    +19
    I got mine a few days ago. I'm supposed to be studying for some very important (and very difficult) exams.
    I couldn't resist it though. I knew if I studied I'd spend all my time thinking about the receiver, so I spent a whole day setting it up and wiring and fitting all the speakers. Heh.
    Even if I fail... totally worth it. :D
