I have an older Denon AVR (non 4k) which is causing issues with rest of set up.
I have SKY Q Ultra HD which I can't bypass through older amp in it's best quality.
I am looking at the Yamaha RX-A4A which shows it has 2 x HDMI outputs, plus a 3rd HDMI output (ZONE OUT)
I run a set up that the current SKY box via splitters etc sends signals to two other rooms so the same channel can be watched at same time. We have secondary SKY Q boxes but they can be a second or so out of sync and painful.
If the RX-A4A would work, this would make things much cleaner and in return better performance.
What I want to do is hook the SKY box (plus other devices) into the Yamaha, then an HDMI to my main Sony 4K TV, plus two other HDMI outputs running into secondary rooms.
I take it one of the two HDMI would work like the main HDMI, plus the 3rd ZONE OUT HDMI need to be switched on to work?
Hope this makes sense?
Mark
Mark
