When you say the old fashioned way for setting up , could you give me more info on this. I would like to give it a go.
There are test tones (white noise) you can use built in (the YPAO calibration uses them but can be used manually).Sorry for my ignorance ,what is classed as white noise? And would you need to put speaker distance in . Then use a spl meter?
A very good amplifier, rightly this review makes a mockery of the review by a "rival" on-line reviewer a couple of months ago which was frankly, total nonsense.
Update, in actual fact after listen on my setup going back to ypao setup , ypao setup sounds more echoing. Mind this is on bbc 1.
I’ve had a go a that steviedr, measured to my mlp and used spl meter. Sounds good. Struggling to tell the difference from ypao set up ,
Level wise after YPAO, it wasn’t far off for the speakers, just had to add a few clicks (bar YPAO naming my front L/R large instead of small), but the sub was way off.
I also got the best result taking a measurement from one position v multiposition.
Intrigued with the angled Atmos measurements.
With the exception of discs, I tend to use the Dolby Surround DSP, sounds really good, especially with some Nowtv 2.1 material, it’s actually very impressive.
I need to experiment more with the dsp’s regarding music.
Edit - watching Thomas the tank engine on Amazon with Surround engaged - I see what you mean, my rears do sound a little unnatural if I pay attention to them - guess it does really depend on the material.
I am using Surround decode.
So what does this do better than the 4400?
The AVRX4400 has a lot going for it, but you'd not get the build quality you'd get with the RXA3070. The DACs are also superior and you'd get more power from the Yamaha. It also includes balanced XLR inputs, but not many will have anything that would benefit from connecting it to the receiver using them. Yamaha receivers also include proprietary DSP that isn't included on any other brand of receiver. This DSP tech can be very effective if used in conjunction with presence speakers and can even be applied to £D immersive formats if you've one of the Yamaha models from the A1070 upward.
