Question Yamaha RX-740A Multi-Zone Syncing?
Discussion in 'AV Receivers & Amplifiers' started by cpc1968, Dec 27, 2018.
  1. cpc1968
    cpc1968
    Dec 27, 2018
    Calif
    Hi, all. I have a Yamaha RX-740A with a 7.1 setup in a TV room “Main Zone” and two wired speakers in the kitchen connected to “Zone 2”. These two rooms are close to each other and when I play both zones (simultaneously) the sound in one zone slightly lags the other zone....yielding an echo like effect. Is there a setting that can adjust for this lag? Any help would be greatly appreciated.
    Paul
  2. dante01
    dante01
    Mar 5, 2009
    45,179
    +10,623
    Use the RXA740's PARTY MODE. This usually results in better synchronisation of the audio in different zones.
    Press the button labelled PARTY on the remote to engage or disengage this mode.
