yamaha remote help
Discussion in 'AV Receivers & Amplifiers' started by slayerad2000, Jun 18, 2002.
Tags:
  1. slayerad2000
    slayerad2000
    Jun 18, 2002
    32
    9
    newtown mid-wales
    hi there,
    i have just bought the yamaha dsp-a5 off a friend of mine and am having trouble getting the remote to operate.
    i have changed the batteries and the red light flashes when i press a button but no functions work on the amp using the remote
    i have also reset to the manufactors settings by doing what it said in the manual
    my friend told me that the remote worked when he first bought it then stopped
    any help at all would be cool
    (i actually paid £200 for the amp and the ns-p300 speaker kit)
  2. bob007
    bob007
    From what i remember of that yammy remote is you have to turn the dial on the top to AMP.
  3. slayerad2000
    slayerad2000
    Jun 18, 2002
    32
    9
    newtown mid-wales
    yeah i've tried that but still nothing
    does anybody know where i can get a replacement remote cheap?
  4. Ricky27
    Ricky27
    Feb 8, 2002
    1,708
    Norwich
    +146
    B4 you go and spend money on a new one,have you tested the remte with other pieces of kit such as your video or tv?
  5. slayerad2000
    slayerad2000
    Jun 18, 2002
    32
    9
    newtown mid-wales
    yeah,
    i've tried it on my technics stereo,toshiba tv,vcr,and dvd player
  6. AOD
    AOD
    Feb 7, 2001
    707
    London
    +4
    The other option is Yamaha themselves.
    How long had your mate had the unit? I thought Yamaha gave a 2 year warranty with some of their units (although I may be wrong about that).
    Get in touch with Yamaha and see what they say.
  7. Stinky985
    Stinky985
    Jun 12, 2002
    674
    Nr Bath
    +6
    From what i remember on the website (or in the manual?) there is a mention of a company that supplies the yamaha remotes - for about £20 i think.
  8. slayerad2000
    slayerad2000
    Jun 18, 2002
    32
    9
    newtown mid-wales
    i was quoted £185.00 off one company and £48.00 off another in swansea
    if you can remember where you saw the £20.00 remote can you let me know
  9. Stinky985
    Stinky985
    Jun 12, 2002
    674
    Nr Bath
    +6
    ok £20 may have been for something else!
    But this is the site i was thinking of:
    www.charleshyde.co.uk
    thery are about £35. Have you looked to see if any other remote can be coded to control the yammy? For example my Sony DVD player (which has a built in decoder) can be coded to control the yammy.
    Or... do without? you can do everything using the front of the yammy anyway. Not ideal if you have to get up to turn the bugger up granted, but it'll save money!
  10. slayerad2000
    slayerad2000
    Jun 18, 2002
    32
    9
    newtown mid-wales
    i've thought about not getting one but i need a remote to do the pink noise test and change individual speaker balances as you can't do this without the remote
    i was told that the remote for the dsp-620 is pretty much the same but i don't know if it will operate all the functions on mine
  11. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    Just seen this site suggested for remotes - you'll have to mail them, but they do a lot of copy remotes as well as originals - might be cheaper than other places?
