Yamaha Remote Code For Yamaha Rxv630rds
Discussion in 'AV Receivers & Amplifiers' started by adewatson, Dec 29, 2002.
Tags:
  1. adewatson
    adewatson
    Sep 7, 2002
    98
    Cardiff Bay
    Does anyone know whether the remote for this amp can control a Pace NTL cable box if so the code would be much appreciated as the manual doesn't quote one.
    Many thanks in advance.
  2. dts_boy
    dts_boy
    Nov 26, 2001
    2,536
    Manchester suburbs...
    +141
    you can't use any other remote with ntl apart from theres, as they use irda codes intsead of normal ones - or summat like that. 'fraid you'll have to use two remotes instead of one!
  3. adewatson
    adewatson
    Sep 7, 2002
    98
    Cardiff Bay
    Thanks for your help.
  4. mostlyharmless
    mostlyharmless
    I don't think that's strictly true. The newer NTL boxes no longer use irda, and can be controlled from other remotes. I used to control mine from a one4all remote until the one4all broke. I think the boxes in the 4100 series are OK.
    Having said that, I haven't found a way to get my Yamaha 630 remote working with NTL (or my DVD player) :(
  5. adewatson
    adewatson
    Sep 7, 2002
    98
    Cardiff Bay
    how can I tell whether I have the newer NTL box?
