Question Yamaha Receiver RX A830 not auto detecting DD/DTS broadcast from cable box
Discussion in 'Home Cinema Buying & Building' started by ZoeB, Jul 5, 2015.
  1. ZoeB
    ZoeB
    Jun 17, 2015
    19
    4
    London
    I have just bought a Yamaha Receiver Model RX A830 and set up with a 4K HD TV and HD Sky (Cable) box with HDMI cables.
    When there are programmes broadcast from Sky box in DD/DTS the receiver does not detect the correct sound format of the broadcast. Instead the receiver shows various other formats on the display, other than the correct broadcast signal.
    I know there are options to change the sound format manually on the receiver, but I have set the receiver to auto detect the broadcast format and it is not working.
    Any help would be greatly appreciated.
  2. apostolost
    apostolost
    Sep 20, 2011
    121
    3
    cyprus
    +28
    hi
    on the remote press "straight" these plays everything as they are (pcm /dts / DD)
    or at any time you want try pressing "info" so that to check various things about source/decoding etc you can check what you hear...
    my receiver is the rx-v767 so it may be deferent
    I hope I helped
