Question Yamaha R-N602 and speakers
oldschooly
Hi, Im new here and I don't have any technical knowledge about amps, speakers and ohms. So please bear with me.
I'm in the process of buying the Yamaha R-N602 because it appears to be the best value for money and has all the connecttions i need.
I already have a pair of new'ish Cambridge Audio SX-50s . They are 8 ohms and was wondering if they would be ok to use with the R-N602? Without causing any issue to the new amp or speakers.
I also have a old pair of Technic speakers from the SB-HD50A (pic attached). These are 6ohms. Are these ok to use with the R-N602 and either a single pair or a second pair combined with the Cambridge Audio SX-50s.
Thanks in advance
oldschooly
Both those pair of speakers would work but you should only use on pair with that amp.
Thankyou Password1
I'm assuming its advisable to use 2 sets of speakers with the sames ohms preferably 6ohms?
I'm trying my best to become au fait with audio tech, and from what I can gage from forums and reviews, is that the lower ohm speakers are suitable tor an R-N602 amp.
password1
ideally only use one pair. 6 ohms means giving the amp a 3 ohm load. speakers drop to lower at certain frequencies. if a 6 ohm nominal speaker drops to 3 ohms the 2 pairs drop to 1 ..5 ohms.
you're straining the amp.
gibbsy
It's best to just use one pair of speakers with any amp. Doubling up on speakers will easily push the amp to it's limits and there is really no benefit in employing four speakers for a stereo signal. Speakers are the most important part of any set up and you should go for the best pair you can afford.
oldschooly
Thanks, looks like i need to do some research into the formula for working out ohms.
oldschooly
ok, in that case I'll stick to using my Cambridge Audio SX-50s (8 ohm speakers) with the Yamaha R-N602, and when I do so i'll select the 8 ohm setting on the amp as per the attachment.
And if i use the old Technics SB-HD50A (6 ohm speakers), then i'll select the 4 ohm setting on the amp, as per the attachment.
deepbeep
The RN602 has outputs for 2 pairs of speakers - switchable A/B (or both). Are you guys saying that it's inadvisable to use this functionality? Or were you just unaware that it had two pairs of speakers outputs?
password1
The RN602 is a stereo 2 channel unit. Its inadvisable to use 2 pairs of different speakers, especially with different ohms.
If you need to use 2 pairs, go for at least 8 ohms nominal or higher but it will strain the amp. make it work harder, get warmer/hotter when pushed loud.
8 ohm speakers will typically drop to 3.5-4 ohms.
If you're using two pairs of 8 ohm nominal speakers, the combined load is 4 ohms nominal but will drop as low as 1.5-2 ohms combined at certain frequencies. Not ideal.
oldschooly
Interesting reading. Also, it makes me wonder why amps with outputs for 2 pairs of speakers include the option to play A+B speaker set at the same time.
If Yamaha wanted someone to play A+B speakers simultaneously then what would be there advisable choices of speaker type to use without causing issues?
deepbeep
Ok, interesting.
Nb, They show this setup in the manual with no caveats about using 8 ohms, etc etc.
It makes sense that the power would be strained, although presumably most people are using one at a time (eg driving speakers in different rooms) which would be absolutely fine.
password1
If you use two pairs of 8 ohms nominal or higher speakers, select the 4ohm setting on the amp. It will work but will be more strain on the amp.
Most amps will give a range of compatible impedences, eg something like 6 to 16 or 4 to 16 or 4 to 8ohms.
Some amps have the option of using either A or B allowing you to switch speakers in different rooms. Some people use them to biwire although biwire is a waste of time imo.
If you're looking at 2 pairs in the same room to better fill the room, I suggest larger speakers instead of 2 pairs of smaller speakers.Stereo music is recommended on 1 pair of speakers.
gibbsy
It was an option for using a different speakers in another room and that was the only positive side of it. A stereo amp is just what is says on the tin. Most high end amp manufacturers do not use an A+B option and just support a stereo pair. Technics may prove the exception to the rule.
password1
An anology would be a car fully laden to its limit and towing a caravan at maximum payload vs a car with 1 passenger. Just go easier on speed humps and struggle a bit more on certain terrains for hills It'll likely be fine in both cases but more strain in the former. If you load the car to much more than the maximum payload I'm sure the car will still move, just not ideal.
deepbeep
Yes, I assume the point would be for different rooms and you would use one or the other 99% of the time.
deepbeep
Or the analogy would be a car shared with two people, but they are rarely both in the car at the same time.
Podcast: LG C1 OLED + JBL Synthesis SDR-35 First Thoughts, plus TV Show & Disc Reviews & more
