yamaha or sony all in one.?
Discussion in 'AV Receivers & Amplifiers' started by deltafx, Aug 22, 2003.
Tags:
  1. deltafx
    deltafx
    Aug 21, 2003
    517
    +8
    ok iam new to all this so need some help.ihave been looking at
    the yamaha av package 25. £299 at comet wot do you think of it.
    http://www.comet.co.uk/comet/html/cache/120197.html
    or as i have such a small bugit of £300. should i go for a all in one
    like sony dav-s550. or the pioneer dcs-303.or313 if i go for the yamaha can i hook up tv/video.dvd/sky.? has anyone seen any
    reviews for this .
  2. madjo
    madjo
    The yamaha av 25 package seems good value.
    Here's some info on the receiver in the package
    http://www.yamaha-audio.co.uk/homecinema/receivers/htr-5630rds/ plus you get a speaker package
    http://www.yamaha-audio.co.uk/speakers/packages/ns-p100/
    You can get it from unbeatable for £229.95 on special order.
    I've just orderd one, hopefully should arrive in 10 - 14 days time :)
    I did have this one on order from Empire Direct
    http://www.empiredirect.co.uk/productdetails/YAM-HTIB45.htm
    but despite it saying on the site that they were in stock, they weren't and the person on the other end of the phone said they didn't know when they would be getting any more in, so I cancelled.
  3. smiddyboy
    smiddyboy
    Did you get the yamaha package madjo ??
    What is it like ?
  4. madjo
    madjo
    I'm afraid not!!
    Unbeatable's suppliers are out of stock and apparantley they aren't getting any more in until the end of September.
    I await with baited breath!!!
  5. smiddyboy
    smiddyboy
    Cheers for the reply,
    look forward to hearing from you then!:smashin:
    Gives me more time to save the pennies before i decide what to buy.
  6. andy572
    andy572
    Dec 4, 2002
    361
    Oop North
    Thumbs up for the 303 here :smashin:
    If you're restricted on budget and/or space, and want some 'fun factor', then I highly recommend it :clap:
    So loud, so tiny :eek:
    However, if you can accomodate a bigger box, 'separates' is the way. Oh, and you'll need a newer system e.g. the 313, if RGB is important. Most of the older all-in-ones, including Sony and Pioneer models, are composite and s-video only. Not that I'm complaining - the s-video pic on my telly is love-ly :D
  7. deltafx
    deltafx
    Aug 21, 2003
    517
    +8
    ok i now have the yamaha av package 25.and i am well pleased
    with it.sounds good to me.but this is the frist av receiver i have broght so what do i know.only ever had a tos tv with pro logic.
    if you are looking for a frist time buy at £299 it a good buy.
