Yamaha on a budget 650, 657, 750 or 757. Differences??
Discussion in 'AV Receivers & Amplifiers' started by seaephpea, May 18, 2005.
Tags:
  1. seaephpea
    seaephpea
    Pixmania had sold out of the 750, so I've had some time to reconsider.
    I'm now quite tempted by the 657 as I can get it for the same price as the 750.
    Just how good is the "tuned for the UK" 750SE sound? As the 657 auto sets up eq (and thus will be far better set up than the 750SE would be...) I was guessing that this would more than make up for the difference. Especially as I'm going to be using fairly rubbish speakers to start with, then upgrading them as I can afford it.
    Has anyone heard the new models?
    Tom
  2. cyberdude
    cyberdude
    I just ordered the 750 from www.tsnversand.de. €417 COD shipped to Portugal. Should be arriving anyday now.
    Didn't really study the differences between the 657 and 750 but had a quick look at the difference between the 750 and 757 and couldn't really see anythng on paper that made me really want the 757. The fact the the 750 is now so well priced and has had good reviews made me go for it.
