Yamaha NSP300
Discussion in 'Home Cinema Speakers' started by Greyhound, Jan 19, 2001.
  1. Greyhound
    Greyhound
    Aug 23, 2000
    64
    Does anyone know if these speakers are any good for both DVD films and audio Cds or can recommend them? Speakers are to be connected to the Sherwood 6090.
    [This message has been edited by Greyhound (edited 19-01-2001).]
  2. Arthur.S
    Arthur.S
    A friend of mine has these, & yes for the price, they are suprisingly solid, & sounded good. The small active sub that comes with the set is no more than 'adequate'. But then this could easily be a future upgrade!
    www.baldyplex.com
