Yamaha HTR-5660 No Digital Signal
Discussion in 'AV Receivers & Amplifiers' started by filmfanatic24, Aug 14, 2005.
  1. filmfanatic24
    Yesterday after I turned off my HDTV cable box and turned it back on again I no longer get audio. I plugged it directly into the TV to make sure it wasn't the box and I do get audio from every channel from the internal TV speakers. However, when I go through the reciever (using Optical Audio Cable) I only get audio from the analog stations and not any of the digital ones or the HDTV ones. I have checked all input settings and everything seems to be correct but I'm just not gettting any audio. Thanks for the time!
