Yamaha HTR-5630RDS setting up speaker volume issues
Fred111
Hi, Hope somebody can help me out, as Yamaha won't. They don't even recognize the model I have here in my study.
Problem:
I have 4 speakers (2 main A and 2 others in the rear left en right outputs).
I want to set the relative volume levels of these, using the manual (Yes Yamaha has a manual for their 'unknown' system). It is all explained on page 19 / 20.
The menu on the amplifier has two parts: '1 SET-UP' and '2 SP LEVEL'.
In part 1 you provide basic info (like I have 4 speakers). Then the system plays a test sound over all 4 and asks 'CHECK OK' : Yes / No.
After choosing 'No' you will enter the second menu part (2 SP LEVEL).
Now you can adjust the volume of each speaker. When satisfied the menu brings you back to the beginning of '2 SP LEVEL'.
This is not what I need. Here you can readjust again, but you cannot store you settings! This apparently has to be done in '1 SET-UP' (with: CHECK OK).
I cannot find any method to store my settings for my 4 adjusted speaker volume levels!
I probably do something very stupid, but I hope somebody can help me.
Thanks!
AVForums Movies Podcast: We review Dune and ask which is the best decade for horror movies?
