Yamaha HTR-5540RDS Test Tone
Discussion in 'AV Receivers & Amplifiers' started by Subrata_dg, Dec 23, 2003.
Tags:
  1. Subrata_dg
    Subrata_dg
    I am very new to all this. I recently bought a Yamaha HTR-5540RDS. Along with it I have two B&W speakers of 100W each. While running the test tone I found a crackling noise on the right speaker when the center speaker tone was being run.
    I have set the speaker setting in the following way:
    Main Speakers : Large
    Rear Speakers : None
    Center Speaker : None
    Sub Woofer : Main
    Just because I have two main speakers only the test tone will run for only left, center and right speakers (though there is no center speaker). I have also noticed some crackling noise while changing the Dsp Modes. I have checked the speaker cables and they are fine. Is this O.K. or is there some other problem with the system.
    Any help regarding this will be very much appreciated.
    Thanks a lot
    Subrata_dg
