Yamaha HTR-3063 Help
natureboss
Hi :hiya: :)
At the moment I have a yamaha htr 3063 with 5 speakers.
I'm looking for a Sub that will be compatible with my amp, and afterwards looking to substitute the standard speakers that were in the box with something higher spec.
Lastly, I need a remote replacement or a universal/harmony product.
Thanks for your help!!
Amplifier SPECS:
Amplifier Section Channel 5.1
Rated Output Power (1kHz, 1ch driven) 100W (8ohms, 0.09% THD)
Dynamic Power per Channel (8/6/4/2 ohms) 110/130/160/180W
Surround Sound Processing CINEMA DSP Yes
DSP Programs 17
Audio Features Compressed Music Enhancer Yes
Surround Sound Processing SILENT CINEMA / Virtual CINEMA DSP Yes
Dolby Pro Logic IIx (ProLogic II)
Audio Features Adaptive DRC (Dynamic Range Control) Yes
Audio Delay Yes (0-240 ms)
192kHz/24-bit DACs for all channels Yes (Burr-Brown)
Video Features HDMI 3D passthrough Yes
Deep Color/x.v.Color/24Hz Refresh Rate /Auto Lip-Sync Yes
Extensive Connection HDMI Input/Output 4 / 1
Dock Port 1 (for optional YDS-12 or YBA-10)
Front AV Input Mini Jack/Analog Audio/Composite
Digital Audio Input/Output: Optical 2 / 0
Digital Audio Input/Output: Coaxial 2 / 0
Analog Audio Input/Output 4 (front 1) / 1
Component Video Input/Output 2 / 1
Composite Video Input/Output 4 (front 1) / 1
Preout Subwoofer
Headphone Output 1
Tuner Section FM/AM Tuner Yes
User Interface SCENE SCENE (4 sets)
Remote Control Unit Yes (Preset)
Audio Technical Specifications Signal-to-Noise Ratio 98 dB or more (250 mV)
General Standby Power Consumption (IR only) ≤1.0W
Auto Power Standby Yes
Dimensions (W x H x D) 17-1/8" x 6" x 12-3/8"
Weight 16.5 lbs.
Shipping Dimensions (W x H x D) 21-3/8" x 8-7/8" x 15-5/8"
Shipping Weight (lbs.) 20.94 lbs.
natureboss
davepuma
Any standard subwoofer will be compatible and will connect from the AV Receiver's subwoofer pre-out connection to one of the inputs on the sub using an RCA coax subwoofer cable. Obviously the AV Receiver is a budget model so I would not spend too much on a subwoofer and speakers. I'm guessing you're in the states? It's hard to suggest what to buy over here as we don't know what is available for the $. As for remotes, I don't really know what is available but have been a (reasonably) happy Logitech Harmony One user for a number of years. I had to replace it as Logitech don't repair them. I got a discount but I wasn't very happy at having to buy a new model as they should be able to repair them. There doesn't appear to be many alternatives these days either so I would suggest taking a look at their range and trying them out. I am not a fan of the buttons on the cheaper models, they are a bit clunky but the functionality is more or less the same.
