yamaha front effects - total waste of time?
Discussion in 'AV Receivers & Amplifiers' started by jasper_mccrea, Jun 20, 2005.
Tags:
  1. jasper_mccrea
    jasper_mccrea
    Dec 5, 2002
    923
    28
    London
    +25
    I'm putting all my stuff into my new living room, and since my amp (mere 750) is capable of running front effects or rear centres, I thought I'd give the front effects a whirl.
    Absolutely useless. Couldn't hear any difference. I had to put my ear beside the speaker to make sure there was something coming out of it.
    And before you ask, yes, it was set up right. Or I ran the auto calibration anyway, and the wiring diagram showed the FEs up OK.
    I think I'll just run a centre rear instead.
    Jasp
  2. skinnyfat
    skinnyfat
    Bear in mind that those front effects only work while using Yamaha's dsp modes. Or am I stating the bleedin obvious and you knew that already :)
  3. jasper_mccrea
    jasper_mccrea
    Dec 5, 2002
    923
    28
    London
    +25
    Yeah, I was switching back and forth between standard and DSP. No difference in what I could hear from the sofa, but when I put my ear next to the speaker, there was definitely something coming out of it.
  4. Ambient Fish
    Ambient Fish
    Apr 28, 2005
    1,640
    Wishaw
    +223
    Jasper, invest in speakers for the rear channels get 2 if you can, 'cause it will make a big difference to your enjoyment. I tried the effects channels when I first got my Yamaha and like you was completely underwhelmed. :eek:
  5. jasper_mccrea
    jasper_mccrea
    Dec 5, 2002
    923
    28
    London
    +25
    No room for two at the back, I'll have to run a single in the centre. :) I think I'm pushing things to get away with that, anyway..
  6. Cliff
    Cliff
    Mar 17, 2001
    5,875
    167
    Kent & overseas
    +3,186
    I do like the effects speakers. Set to 70mm movie I find they do open up the whole sound.
    Having said that, if you only have the option of front or back then the back centres are much more important
