Yamaha DVXS200 Help Please...
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Eddie_M, May 28, 2005.
  1. Eddie_M
    Eddie_M
    Feb 27, 2005
    11
    I have had the Yamaha DVXS200 system for a little while now and am very pleased with it.
    But, I have just got hold of some Region 1 films and it will not play them. I thought that it was multi region,........hmm Wrong.
    If anyone can help with this to make region free I would be very grateful.
    Many thanks
    Edd
    :lease:
  2. Darthred1977
    Darthred1977
    Hi.
    Try
    1/ Power ON
    2/ Press PLAY
    3/ 2 7 4
    4/ 222222005255
    5/ Play
    :clap:
  3. Liberator
    Liberator
    Nov 22, 2005
    22
    3
    The hack suggested by 'Darthred1977' will NOT work!:lesson:
    The hack that does work should be undertakern by your local Yamaha dealer / service centre as it involves sending the unit into service mode - get it wrong and you'll lock it up!
    Hope this helps?:)
