yamaha dvx s80
Discussion in 'Blu-ray & DVD Players & Recorders' started by weeduggy, Feb 16, 2003.
  1. weeduggy
    weeduggy
    can some body help me? I've got a yamaha dvx -s80 which is a cinema in a box solution. it comes with a yamaha dvd-s80 player. in the manual it says it is region two but it has an example of labels on dvd's that it will support . one of them says 'all 'does that mean all regions or something else. If it is just region two can i chip it or i am i stuck with it as it is.by the way i am pretty much new to all this home cinema stuff so any help would be aprreciated
    scott
  2. Squirrel God
    Squirrel God
    "All regions" means a non-region coded disk.
    You can get it 'chipped' or maybe a handset hack would work. Check out the handset hacks at Total DVD (choose it from the "Official forums of..." drop down list at the top).
