Yamaha DVX-S120 firmware
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by bosstjan, Dec 1, 2004.
  1. bosstjan
    bosstjan
    Hi! :cool:
    I bought Yamaha Home Cinema System DVX-S120 about year ago.
    It works great, it recognizes all formats ... except :suicide: it can't play divx CDs :suicide:
    Does anyone know if there is some firmware upgrade available for this system (actually for the DVD player DVR-S120)?
    I would really appreciate it :rolleyes:
    tnx
  2. andywilks
    andywilks
    don't think theres any firmware upgrade but I will ask Yamaha. see my other posting for how to multi region it.
    AW
  3. bosstjan
    bosstjan
    Well, I appreciate it. tnx.
    and multi region is not a problem, it's done, just those DIVX...... :cool:
    tnx again
    B
  4. karel
    karel
    Hi Bostjan
    Does the multi region also work on my dvr s120?
    I would love to know how to that.
    Regards
    Karel
  5. bosstjan
    bosstjan
    Well, Karel, my set was already supporting all regions when I bought it :cool:
    But there is a remote hack for the Yamaha DVX-S120 (dvr s120 + speakers). :) Check this topic remote hack for the Yamaha DVX-S120
    I didn't test it, but as you can see, others did. Hope it helps :thumbsup:
    regards, B
