Yamaha DSPAX750SE & NAD C350 integration?
Discussion in 'AV Receivers & Amplifiers' started by Katnap, Jun 14, 2004.
Tags:
  1. Katnap
    Katnap
    May 3, 2004
    38
    Kent
    +4
    Hi all
    I have the Yamaha 750 on order with some Monitor Audio Bronze speakers (B4, BFX, B1 centre & sub) to complete the AV setup. I already have a NAD C350, Arcam CD72.
    My question is, should I continue to use the NAD and Arcam units alongside the Yamaha, or connect the Arcam directly into the Yamaha? I understand the Yamaha has a pre-out connection and presume this can be wired into the NAD.
    What about the speaker connections? Is this all too complicated or is it worth using a separate amp for CD Audio playback? Any suggestions gratefully received. :)
  2. wookie
    wookie
    This may sound obvious but listen to the Yamaha as a pre against the NAD & make up your own mind.
    You could always use a switchbox between the pre outs of the NAD and Yamaha and the main ins on the C350 (switch between pre amps)....
