Yamaha DSPA1-Front (high) effect channels- ANY GOOD?
M
martin
Is anyone using the front effect speaker outputs from their Yamaha DSPA1/DSPAX1/DSPAZ1. I would like to know if it is worth the extra outlay of another set of speakers/mounting brackets or shelfs + speaker wire. The front effect channels should sit above your main front speakers head height ,slightly further apart according to Yamaha's instructions. Any feedback whould be welcomed before I start to spend money for maybe something that doesn't justify the outlay.
gringottsdirect
Originally posted by martin
Is anyone using the front effect speaker outputs from their Yamaha DSPAX1 .
Sure everyone will disagree with me but I tried them, didn't think it was worth the wifey aggro for the audible gains.
Haven't used them since.
Reiner
Since we hopefully all know that the front effects only work when the DSP modes are engaged the question is: do you like them?
If yes, I would consider the front effects, if not forget about it ....
C
Chimp
I think they are rubbish to be honest a gimmick for people in Japan hehehehehe
Still I love my Yammy DSP-A3090 to bits, but it's getting old and embarrassing
DSP-AZ1 or VSA-AX10 Mmmmmm
Podcast: Best Home Cinema Sources and B&W 805 D4 Speaker Review and more...
