Yamaha DSPa-595a OR Sony-STR-DB830?
Discussion in 'AV Receivers & Amplifiers' started by DaBuzz, Jan 8, 2001.
Tags:
  1. DaBuzz
    DaBuzz
    Which would you choose out of these two amps? Which is suppose to be better? If either is better, will it be a great difference or hardly noticeable?
  2. tan1415
    tan1415
    Both are pretty good amps.But different. the DSP has no tuner and the Sony does.
    i think you have to try them out and listen.
    I think that the Str-DB 930 is better than both.
    Or what about the DSP-A5 from yamaha. If you don't need a tuner this Amp is an excellent choice.
  3. pauld
    pauld
    The DSPA5 is the replacement for the DSPA595a and they are basically the same amp
    Paul.
