Yamaha dsp630 connect to record deck - how?
Discussion in 'AV Receivers & Amplifiers' started by ncmike, Feb 23, 2003.
Tags:
  1. ncmike
    ncmike
    There does not appear to be a phono connection on the Yamaha dsp ax 630. Does any one know if it is possible to connect a record deck. Thanks in advance.
  2. rjw
    rjw
    Sep 6, 2002
    204
    Bath
    +5
    You'll need a phono pre-amp to connect between the turntable and a line-level input.
    You can pick them up relatively cheaply if you look around.
  3. nathan_silly
    nathan_silly
    Nad PP-1 at £40, and the Project at £60
  4. pat clancy
    pat clancy
    Sep 10, 2000
    1,743
    LONDON
    +27
    hi has your turntable got a switch anywhere,my aiwa has,if so switch it and you may be able to connect it to line in,i forget what they call this switch,hope this helps
  5. ncmike
    ncmike
    Thanks guys. I will look into it.
