Yamaha DSP-Z9 - calling other owners...
Discussion in 'AV Receivers & Amplifiers' started by AndyGo, Mar 12, 2005.
Tags:
  1. AndyGo
    AndyGo
    Oct 5, 2003
    94
    9
    Wiltshire
    Hi there,
    I have a DSP-Z9 myself & was wondering if any other owners could possibly take a (very) little time to confirm something for me if at all possible.
    When you select 2CH stereo on the surround options, do the amps relays make a clicking sound twice ??
    I have only just noticed this happening on mine, it's probably been happening all the time but just wanted to check that someone else's does the same.
    When it's on direct analog or 9ch stereo it just changes over as normal, but when you press the "stereo" selection button on the remote again and it goes to 2 ch stereo there is a relay click inside the amplifier (similar to when you power it up & the relay kicks in before the power amps are activated) and then a click as the amplifiers activate.
    If anyone could take the time to check this for me & fill me in on whether yours does the same, I would be extremely grateful.
    Cheers,
    Andy
  2. AndyGo
    AndyGo
    Oct 5, 2003
    94
    9
    Wiltshire
    Is there anyone who can check for me plese ???
    Cheers,
    Andy
  3. Howard0000
    Howard0000
    Jan 11, 2003
    1,104
    48
    Surrey
    +100
    A relay clicks inside my Yamaha when I switch between stereo and surround sound too...
  4. recruit
    recruit
    Hi Andy,
    I replied to you're email ref to this post and i am sure it is ok.. :)
    John
  5. AndyGo
    AndyGo
    Oct 5, 2003
    94
    9
    Wiltshire
    Thanks for the info guys, much appreciated.
    If someone with a Z9 could try it out to finally confirm then that would be great also.
    Cheers,
    Andy
  6. Howard0000
    Howard0000
    Jan 11, 2003
    1,104
    48
    Surrey
    +100
    Is it a problem? I think it's standard practice through the Yamaha ranges :)
  7. AndyGo
    AndyGo
    Oct 5, 2003
    94
    9
    Wiltshire
    Nope, no problem. Just hadn't noticed it doing it before. Although the relays do clunk about a bit more than on my old A1. Lot more going on inside this beast though I s'pose.
    Was just interested to see if another Z9 owner could confirm the same.
    (Although as yours does it, I would imagine it's probably fairly standard across the range nowadays.)
    Cheers,
    Andy
  8. Ru55
    Ru55
    Jun 12, 2005
    79
    Mids
    Yes mate, my Z9 clicks twice on change over!
  9. fermthe
    fermthe
    Apr 26, 2008
    11
    Yes it does that exactly and only on 2 chann stereo not on 9 not on anything else
  10. HeweyBoy101
    HeweyBoy101
    Jul 9, 2004
    897
    Lancing, West Sussex
    +82
    My Arcam amp has a loud relay click when selecting stereo direct mode (i.e. stereo analogue only - all digital processing and video circuits are then turned off / removed from signal path). I guess that is waht the Z9 might be doing when you select stereo - switching to stereo direct mode?
