Yamaha DSP E800 + Tecnics AA amp?
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by degsy, Dec 16, 2003.
  1. degsy
    degsy
    Dec 1, 2003
    95
    11
    Solihull
    +9
    Currently running Technics CD and Amp through pair of B&W 602s. Just added pannie S75 DVD and considering next step on home cinema sound system. Question is do I replace existing amp with an AV Receiver (and probably lose out on stereo performance?) or add extra channels by way of a processor such as the Yamaha DSP E800 for home cine use?
    Anybody gone through the same thought process?:(
  2. Johndm
    Johndm
    Jan 25, 2003
    1,832
    Bedford UK
    +67
    I used to run three Technics class AA amps, fed from a DVD player with onboard DD/DTS decoders.....pretty damm good I thought!
    Now have a Sony VA555ES instead (retained the best AA amp for twin centre rears only), and......well......its just sooooo much better.:smashin:
    I reckon the Sony is far better at music (stereo performance) than the class AA's were......
    AV amps 'aint half got better since the war...:D
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    depends on what you want to spend, an AV amp with preouts and you can still use current setup for stereo!
