YAMAHA DSP E492......Protection
S
Sharpy14
A query for anyone with a long memory and knowledge of a processor before processors became high end.
My 492 was working fine, and then for no reason, the display dimmed, and said either "PROTECTION" or "PROTECTED". The next time I tried to put it on, nothing, dead, no power. Changed fuse, still nothing.
Anyone had this problem?
simonb68
I did, after spilling some water in it's innards :blush: . After leaving it to dry out it was fine. Regarding yours, given it's age I would suspect something might have worn out. Or it may be an internal fuse (if it has one), if that is not the fuse that you changed.
I have mine for sale at a very low price if you are interested, rather than bothering to look at repairs. If you are then let me know and I will send you the link to the For Sale thread on here.
Simon
Reiner
Check the speaker cabling, could be a shortcut. Look out for the tiny strands.
In fact you could try to disconnect all cables and see if the unit powers up - if not it's a bad sign and it probably needs service/repair.
H
heavenly93
This reply might be late!! But did you also check the setting of the Impedance selector on the rear.
