Yamaha DSP-AZ2 vs. Denon AVR-3803
Discussion in 'AV Receivers & Amplifiers' started by ripclaw, Apr 16, 2003.
Tags:
  1. ripclaw
    ripclaw
    Jan 29, 2003
    249
    +10
    I'd like to know which is better : the Denon AVR-3803 or the Yamaha DSP-AZ2. I apologise if this has been asked before. I need to make a purchasing decision. My speakers of choice are Paradigm Monitor 7's for the fronts, mini Monitor or Monitor 3's for the rears.
  2. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    Better in what terms?
  3. ripclaw
    ripclaw
    Jan 29, 2003
    249
    +10
    Better in terms of features, sound processing, value for money. More importantly, does the Yammy sound better than the Denon?
    The DSP-AZ2 upconverts from composite video to S-Video, but the Denon can upconvert from composite and S-Video to Component. Is this important?
  4. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    That is an question only you can answer. :)
    Depends. Do you need it, i.e. do you have equipment with component connections (projector for example)?
    If not it's probably not important.
    I suggest you borrow both units from a dealer and compare them in your house with your speakers. Try them out for a weekend and then decide. Especially the sound issue is very "personal". ;)
  5. Brox
    Brox
    Oct 26, 2000
    313
    16
    Marlow, Bucks, UK
    Don't tell me you want to buy online for a discount so have no intention of actually listening to them before you buy, otherwise why are you asking the question?
  6. ripclaw
    ripclaw
    Jan 29, 2003
    249
    +10
    I do plan on listening to both. I just wanted to hear from others that have auditioned both products, and get their opinions and what I should look out for. And I won't be buying either of these online.
  7. tony m
    tony m
    ripclaw
    i have a 3803 sounds fantastic with movies and music
    any bad points.. looks dated!!
    had a quick demo of the yammy
    soundwise as good as the denon in movies if not in music
    and one point about prices
    Local dealer price(global)
    The denon £900
    Online price £680
    asked AFTER the demo can he match,,no chance
    so he had a chance
  8. kryten
    kryten
    Apr 9, 2003
    522
    Swindon
    +14
    but did you say 'if you can't do it for 680 I'll get it elsewhere' or 'i can get it for 680 online, wha'ts your best price'??
    _OF COURSE_ a shop offering knowledgable staff and demo facilities cannot match the prices of an internet based box shifter, but given a chance, they will probably try and get you a deal of sorts.
  9. tony m
    tony m
    kryten
    Yes gave them every chance , was willing to pay a little above
    internet price
    But it was the dismissive attitude,They will be grey,not official etc
    And i have spent ££££ with them
    Global are known for not being cheap at the best of times
