Im having a few issues with my current Yamaha DSP-AX763 and cannot for the life of me get it sounding right. Ive tried auto PEQ which sounds too harsh and bright, manually set up from scratch using GEQ and also half and half by using auto for distances and levels then GEQ for channel frequencies. However my centre channel always sounds odd, almost muffled and the fronts sound a bit odd too, its hard to explain but my old Sony DG910 although didnt immerse you as well as the Yamaha for surround effects, did sound much better for dialogue and across the front channels.
Ive spoken to my local dealer where I got it from for advice as Im not making progress, they suspect a bad speaker / amp match and have very kindly offered to swap it out for another amp. My quandary now is what to go for and is this a good idea or do I persevere?
Im considering the following:
Sony 2400ES Good reviews and I was very happy with my old Sony 910.
Denon 1909 Same price as the Yamaha, recommended for use with Canton speakers, however out of stock everywhere!
Onkyo 606 Good reviews and lots of happy users, however lacking in the looks department!
The other option is to use this as an opportunity to move up and get a higher spec amp, I dont want to spend silly amounts and at the same time dont want to go overkill for my speakers, so what should I be considering if I did this, maybe the Denon 2309, or Onkyo 806 perhaps?
Any suggestions or thoughts welcome . Thanks.
