Yamaha DSP-AX759 with my old speaker set
rdbushell
Joined
Jul 29, 2004
Messages
25
Reaction score
Points
11
Age
41
Just bought a Yamaha DSP-AX759SE to replace my denon dht-500sd as the amp of the denon dht-500 has packed in! Just wondering if anyone can tell me if the speakers from the system will be ok for my new amp? as the sub is not active how do i connect it to my new amp? or do i need just a new sub?
spec for speakers as follows:
Application 5.1 Home Cinema Speaker System with passive subwoofer
Satellite Speakers
Model name / number SC-A500SD / x4
Construction 2½-ways, closed
Maximum power capacity 100 W / 40 W
Frequency respone 120 Hz - 90 kHz
Tweeter 19 mm
Impedance 6 ohms
Center Speakers
Model name / number SC-C500SD / x1
Frequency response 120 Hz - 90 kHz
Tweeter 19 mm
Impedance 6 ohms
Subwoofer
Model name / number DSW-500SD / x1
Construction Bass reflex system
Maximum power capacity 100 / 50 Watt power capacity
Frequency response 29 - 240 Hz
Bass chassis 160 mm
Did you ever get an answer on this one?
Did you end up using the Denon speakers or replacing the lot?
Rgds
Richie
RESTORATION vs. REVISIONISM: At what point do 4K video and audio 'upgrades' cross the line?
Back
