Yamaha DSP-AX757SE & Bose 7.1 Speaker Setup Query.
Discussion in 'Home Cinema Speakers' started by Vipers, Oct 28, 2005.
  1. Vipers
    Vipers
    Oct 16, 2005
    4,099
    Stevenage
    +650
    I've just invested in a new home cinema setup, Pioneer PDP-506xde, Denon 1920 and Yamaha DSP-AX757SE, I've bought 2 more Bose cubes to add to the 5.1 setup I've already got, obviously to use 7.1 that the amp offers. Now that I've gone to hook everything up I found a problem, with Bose everything goes through the Sub, which I'd forgotten about, but as my setup is about 5 years old there is only inputs for 5 speakers on the sub, to do it properly I'd imagine it would be better if there were 7 inputs, So shall I leave it as it is set up now for 5.1 into the sub and put the 2 new rears direct from the amp, or will this cause an imbalance in the sound. Bloody Bose, why do they have to make it so complicated.
    Thanks,
    Vipers
  2. Hoggers
    Hoggers
    Hello.. :hiya:
    If I recall the Bose speakers need to be connected to the Sub in order to function correctly.
    I used to have the old Acoustimass Cubes and remember reading that it was advisable not to connect directly to the Amp... so I am guessing the same holds true here.
    Hope this helps,
    Alastair
