Yamaha DSP-AX750SE or RX-V750?
Discussion in 'AV Receivers & Amplifiers' started by Lee James, May 9, 2005.
Tags:
  1. Lee James
    Lee James
    Dec 11, 2004
    315
    What's the difference between these two models? The RX-V's radio tuner would be nice, but only if there's no difference in sound qulaity.
    What do "DSP-AX" and "RX-V" mean anyway?
  2. Howard0000
    Howard0000
    Jan 11, 2003
    1,066
    48
    Surrey
    +88
    As far as I'm aware the "DSP" range don't have tuners.
    The RX-V750 looks identical to mine. Specifications don't seem much different either. Only addition I can see is an extra 5 watts per channel.
    The RX-V750 and the DSP 750 look pretty much the same, too. And I doubt there'll be any difference audio-wise. It's up to you whether you want a radio or not.
  3. SBanga
    SBanga
    Mar 23, 2005
    2,026
    Leeds, Yorksha
    +6
    Buy the DSP. You'll be able to audition it first, have a more reliable and faster warranty and recieve it quicker. Its also supposed to have an upgraded power supply from the RXV and a "UK tuned sound". Plus you'll be supporting British business!!! :thumbsup:
  4. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    The DSP range are so-called AV amplifiers (no tuner) while the RX range are AV receivers (i.e. AV amplifiers with tuners).
    I guess DSP-A stands for "Digital Signal Processor - Amplifier" while RX just means "Receiver". The X and V respectively were added a few years back only.
    There are also DSP-AZ models, placed above the AX series, while the older flagship model was just called DSP-A1.
