Yamaha DSP-AX750se mode query
Discussion in 'AV Receivers & Amplifiers' started by Saxon, May 24, 2005.
Tags:
  1. Saxon
    Saxon
    Nov 30, 2002
    54
    I recently upgraded my Yamaha DSPE800 to a Yammy AX750SE and am curious why the display on the Yamaha doesn't show 'Dolby Digital 5.1' on its front display when playing a Dolby Digital 5.1 soundtrack - instead it shows every possible thing apart from that!! Right now I've got it set to 'enhanced surround' but I'm certainly not blown away by the rear channels.
    Am I doing something wrong?
    Thanks,
    Saxon
  2. Van300
    Van300
    Jan 3, 2005
    182
    Derby, UK
    +11
    You have it wrongly setup. I think 'enhanced surround' is a stereo signal brought to the back at quiter volume-it needs to say 'straight' I think.
    It should show the DD symbol when it is in Dolby Digital 5.1.
  3. *ChrisB*
    *ChrisB*
    Apr 22, 2005
    310
    Berkshire
    +11
    With the amp processing a Dolby Digital signal it will show "Sur.Standard" or "Sur.Enhanced". If you press the display button on the remote it will bring up the 'on screen display' showing you the input which you will then see as Dolby Digital.
