Yamaha DSP-AX750se bought for £329.94 !!
Discussion in 'AV Receivers & Amplifiers' started by Gazza.b, Apr 25, 2005.
Tags:
  1. Gazza.b
    Gazza.b
    Just thought I would share with you a great deal I got from Richer Sounds last weekend.
    I've been after the yamy 750 se for a while and its currenty selling for £349.95 at RS. After a bit of research on line I found the cheapest you could get the machine delivered was £339.94 from Peter Tyson:-
    http://www.petertyson.co.uk/yamahadspax750se.shtml
    Armed with this info I went to RS on saturday and they price matched and beat them by an extra tenner bringing the price down to £329.94, a bargain! :smashin:
    All you need to do is bring in a copy of the webpage as evidence and a telephone number for them so they can verify the price.
    Got the amp all set up now and it sounds great, I would recomend it
    Gaz
    :thumbsup:
  2. Tejstar
    Tejstar
    Dec 4, 2002
    22,482
    London
    +990
    This will start getting even heaper now that the 757 (its successor) is selling in some places.
  3. *ChrisB*
    *ChrisB*
    Apr 22, 2005
    310
    Berkshire
    +11
    I'm after one of those too & it looks like Tyson's have now dropped the price to £329.95 So I'm off to Richer Sounds tommorow !
    Top tip, thanks Gaz :thumbsup:
  4. des_pd_ tdi
    des_pd_ tdi
    Apr 11, 2005
    71
  5. MattMcSpirit
    MattMcSpirit
    Apr 7, 2004
    113
    Bracknell
    +4
    Richer sounds should price-match that shouldn't they?
  6. BenedictGilman
    BenedictGilman
    What's the difference between the 750 and the 757?
  7. mickbarlow
    mickbarlow
    Dec 1, 2004
    532
    +7
    i think i read the new '7' versions have rgb pass through?
  8. BenedictGilman
    BenedictGilman
    *passes hand over head and makes whooshing noises*
    Uh . . . ? What does that do?
