Yamaha DSP-AX7506E and RX-V1400 7.1
Discussion in 'AV Receivers & Amplifiers' started by chrisyd, Aug 23, 2004.
Tags:
  1. chrisyd
    chrisyd
    Jul 29, 2004
    83
    Sorry for the idiot question but can anyone tell me the main difference between these 2 models (besides that the v1400 is 7.1) and almost £200
    I am interested in the above models due to the upconversion capabilities as I plan to connect a Component DVD and S-Video Sky and S-Video VCR to the receiver.
    thanks
  2. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    10,964
    2
    +3,334
    The big one is that the 1400/2400 have THX Select certification and processing and a bit more grunt. Might be a phono stage as well.
    ToF.
  3. wandersen
    wandersen
    The differences are as follows:
    - 1400 is a receiver, not just an amplifier;
    - 1400 has THX select certification;
    - 1400 is not just higher power (110w DIN per channel), but also have a MUCH more powerful power supply. The 1400 will therefore be able to drive more channels at a higher volume for longer periods and will not be as "throttled" by an inadequate power supply as would the 750.
  4. Dfour
    Dfour
    Jan 19, 2004
    3,998
    71
    Bracknell
    +85
    They also have a MM phono stage :D
  5. MS-Yam
    MS-Yam
    Aug 12, 2004
    235
    16
    I don't know whether your funds allow, but I found the Yamaha 2400 RDS on the web today at an amazing £650, thats 350 snots off the original price! It also won the a test in What Hifi against the new Denon powerhouse, and the Arcam AVR300! I have the DSP-AX640SE which is fine, but I know I could drastically improve my system with a 2400. Unfortunately i'm skint!
  6. jasper_mccrea
    jasper_mccrea
    Dec 5, 2002
    882
    London
    +20
    The 750 has a phono stage too. And does 7.1. The 1400 and the 2400 can do 7.1 and drive the two front presence speakers, too, if I'm not mistaken. The 750 can do 5.1 plus the front two, or 7.1 minus the extra fronts.
  7. chrisyd
    chrisyd
    Jul 29, 2004
    83
    MS-YAM,
    I may be able to stretch to £650 at a push. Can you PM me and let me know where you saw the 2400 at?
    Just realised when I got home that my VCR does not have S-Video (only a SCART socket) but I presume I can get a scart to composite cable that I can connect into any of the Yam receivers?
    cheers
  8. MS-Yam
    MS-Yam
    Aug 12, 2004
    235
    16
    I'm not too sure about the composite connections, but if you look at www.superfi.co.uk, on their home page you will find the Yam at £650. When you click on the link, it will bring up a good description of the amp, with all connections, spec etc you need to know.
  9. MS-Yam
    MS-Yam
    Aug 12, 2004
    235
    16
    P.S. You will be using a DVD won't you, not just a VCR??
  10. MS-Yam
    MS-Yam
    Aug 12, 2004
    235
    16
    Sorry, one other thing..
    Assuming you are using it with good components, if you can stretch to this amp, my advice is go for it! I got myself a DSP-AX640SE, which dont get me wrong, is superb for the money. But if I had the extra, I know in my own mind the step up would be a hell of an improvement. I used to have a Mordaunt-Short Premiere satellite system, which it was perfectly matched to. I have now upgraded to a full size Mordaunt-Short Avant set up i.e. MS906 fronts, MS905 centre etc, and I feel that the 2400 would be a hell of a match. What other equpiment are you using??
  11. sharper
    sharper
    Jul 24, 2002
    596
    SW London
    +11
    Got the 2400 about a week ago. Very pleased :thumbsup: :thumbsup: paid £689 so not too bad for £650 bite their arm off!
  12. chrisyd
    chrisyd
    Jul 29, 2004
    83
    Thanks guys,
    I have just ordered the receiver from superfi :clap:
  13. sharper
    sharper
    Jul 24, 2002
    596
    SW London
    +11
    Enjoy!
    take your time setting it up :lesson:.
    You'll then want new speakers I do dont know what to get?
    New DVD?.......................................CD..................oh bloody hell:devil:
  14. jasper_mccrea
    jasper_mccrea
    Dec 5, 2002
    882
    London
    +20
    Can anyone with the 2400 tell me if it has audio delay assignable to inputs. eg could I have 60ms for VCR, and 100ms for DVD?
    The 750 doesn't do this, and a look at the 1400 manual doesn't give me any clues, either.
  15. Dfour
    Dfour
    Jan 19, 2004
    3,998
    71
    Bracknell
    +85
    Why bother at all. Just run the vcr to the tv with a scart and the audio to the amp if it has audio out on it.
  16. ktng
    ktng
    May 9, 2004
    171
    16
    UK
    Another difference between the 750 and the 1400/2400 is the YPAO. The YPAO on all 3 check the wiring, distance, phase, size and set the level, but the YPAO on 1400/2400 can also equalize each of the speakers across 7 frequency bands.
