Yamaha DSP-AX750 and video switching
Discussion in 'AV Receivers & Amplifiers' started by Malky1903, May 14, 2005.
Tags:
  1. Malky1903
    Malky1903
    Jul 2, 2003
    1,937
    48
    Aberdeen
    +64
    Need a little help here as I'm now planning to route all video through my amp. I need to know the best way of connecting my cables. My set up is as follows with the relevant video/audio inputs. I've ruled out composite connections from the off.
    PJ > Component, S Video
    TV > 1 x RGB Scart, 1 x Scart [S Video compatible]
    DVD > Component, S Video, 1 x Scart
    VCR > 2 x Scart
    Sky+ > 2 x Scart, S Video
    I would like to be able to view DVD, Sky+ and VCR on both the TV and the PJ.
    Thanks in advance.
  2. pragmatic
    pragmatic
    Nov 9, 2004
    12,150
    +1,647
    Use the best signal you can for each source,
    For the tv i have s-video out from my amp, and use component to my pj.
    I have component and s-video from my dvd to amp, thus the component will be used for the projector while i can also watch dvd using the tv if i want.
    I have a dvd recorder which has component out and alos a rgb in, so i use it to convert the rgb from my cable box to component to use on the amp. I also send s-video from the dvd recorder to, for the same reason as the dvd player. For your sky+, you could output it to s-video or get a box that turns the rgb to component.
    Everything else use's lower quality output usualy composite, so i just let the amp upconvert it, to which ever i'm using, as it upconverts to both s-video and component at the same time, its very good.
    You could maybe get some sort of component splitter and have component to both your tv and pj, using a component to rgb converter. To be honest though on a standard tv i doubt you will notice much difference between s-vid and component.
    Also a standard vhs actualy outputs composite even though it has scart, unless its a super vhs in which case you'd get svideo from it.
  3. Malky1903
    Malky1903
    Jul 2, 2003
    1,937
    48
    Aberdeen
    +64
    Thanks for the input gazbarber. I was hoping to avoid any kind of switch box and just use cables if I can. As my S Video socket on the TV is behind the front panel, would it be wise to use an S Video-Scart cable from the amp to the TV and plug it into AV2?
  4. pragmatic
    pragmatic
    Nov 9, 2004
    12,150
    +1,647
    Yea that would be fine just make sure that the tv has an s-video scart. It is usaly the one that isn't rgb. Also you may have to put the tv into s-video mode i.e. select it as some tv's would just show a black and white picture other wise.
  5. Malky1903
    Malky1903
    Jul 2, 2003
    1,937
    48
    Aberdeen
    +64
    Success! Managed to get all the cabling sorted. Went out and bought some cables this afternoon and everything works fine although the VCR picture has like a major screen door effect. Any ideas what's causing this? I have a scart to s-video cable going to the amp and an s-video to scart going into AV2S on the telly.
  6. FaxFan2002
    FaxFan2002
    Jan 25, 2003
    2,422
    63
    Andover
    +159
    On the denon amps it points to a problem with VCR's - you need to enable "time based correct" on the VCR, if indeed you VCR has such a thing. I would assume this is a generic AMP / video switching issue.
  7. Malky1903
    Malky1903
    Jul 2, 2003
    1,937
    48
    Aberdeen
    +64
    Will look into that. It's something I've never heard of before, the time based correct thing. The VCR is relatively new, about 3 years old so may have such a setting.
  8. pragmatic
    pragmatic
    Nov 9, 2004
    12,150
    +1,647
    Maybe just because composite is such low resolution :(
  9. doctorjuggles
    doctorjuggles
    Aug 31, 2004
    799
    London
    +19
    Could someone in this thread possibly help me with this question then?
    I wasn't sure where to ask it, as I wasn't sure if anyone in the receiver forum would know about JSTech converters.
