Yamaha dsp ax750/757
Discussion in 'AV Receivers & Amplifiers' started by Kaseryn, Jul 24, 2005.
Tags:
  1. Kaseryn
    Kaseryn
    Hi everyone. First time post here.. i currently own a dspax630es and had for some time been looking at the 750 as a replacement. However i now see the 757 is out and so have a question that some of you may be able to help with. Namely that, having look around at a lot of reviews and such i've not been able to determine wether or not these amps will do digital conversion on the audio to outputs.. something i found annoyingly lacking in the 630. By that i mean.. it would be nice to have analogue audio sources output to the digital out, then you could have just the one hookup to a recording device. With all the electronics going on you'd think they might have done this ... have they for these later models?
    TIA :)
  2. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    not that im aware, im pretty sure all amps just pass through the digital signals
