Yamaha DSP AX620 etc
Discussion in 'AV Receivers & Amplifiers' started by gmoss, Feb 28, 2003.
Tags:
  1. gmoss
    gmoss
    Does anyone know if it is possible to have the power supply to Yamaha DVD, CD and AV AMP changed from UK 240 Volt to USA 110 Volt. I would prefer to modify the kit than use step up transformers. I will check the DVD again but the amp definately does not.
  2. sounddog
    sounddog
    Dec 11, 2002
    3,438
    107
    Leicestershire, UK
    +477
    Sorry if this is a daft question ... but have you checked that they don't have universal power supplies in ... especially the DVD player is likely to.
    Otherwise ... have you tried contacting Yamaha?
