Yamaha DSP-AX620 component inputs
Discussion in 'AV Receivers & Amplifiers' started by AndyF, Jun 28, 2001.
Tags:
  1. AndyF
    AndyF
    Does anybody know if the component inputs on the DSP-AX620 can handle the RGB from my Wharfedale DVD player?
    Thanks,
    Andy.
  2. lmccauley
    lmccauley
    Oct 24, 2000
    3,484
    Newcastle
    +295
    It is very unlikely. I don't know of any amplifiers that can switch RGB.
    Cheers,
    Liam
  3. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    You should be able to swich the RGB through your amp. You will need a SCART to 4 phono (RGB+S(composite video)), and one that will go back, ie RGB+S to SCART.
    You should run the sycn through the composite section of the amp.
    It should work since it does on the Denon AVC A1SE etc.
    Rick
  4. lmccauley
    lmccauley
    Oct 24, 2000
    3,484
    Newcastle
    +295
  5. AndyF
    AndyF
    OK, thanks for that.
    I just wanted to be sure before I blow a large wad on a couple of leads.
    Cheers,
    Andy.
