Yamaha DSP-AX2 and RGB
Discussion in 'AV Receivers & Amplifiers' started by Percy Hamer, Apr 15, 2002.
Tags:
  1. Percy Hamer
    Percy Hamer
    Yamaha DSP-AX2 has 2 inputs for component video and 1 component video output (incl. OSD infos). Some populations cite that the Ax2 is capable on RGB switching instead of component video. Could anyone answer me the following questions:
    - Ist it possible to switch RGB instead of Component Video ?
    - What about the OSD signal, will the RGB output be disturbed by this ?
    - Are the S-video inputs converted to Component Video on the CV output ?
    - What about S-Video conversion with RGB out ?
    I would appreciate any info on this, Yamaha hasn´t answered my inquiry 1 week ago.
    Cheers, Percy.:confused:
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    - Yes. You may also need to connect the composite to allow the SYNC signal to pass through
    - Don't know (can the OSD be switched off?)
    - No
    - Not applicable
