Yamaha DSP AX-620
Discussion in 'AV Receivers & Amplifiers' started by Glasswalker, Jun 12, 2002.
Tags:
  1. Glasswalker
    Glasswalker
    I've got the Yamaha DSP AX-620 Amp and it's superb doing DD 5.1, however I've tried DVDs using the DTS sound (like Gladiator) and I can't hear anything. The DVD player is setup to output DTS and the Amp is set to decode it but I get no sound.
    Any suggestions?
  2. S H A D O
    S H A D O
    Mar 16, 2001
    10,301
    United Kingdom
    +1,575
    Make sure the dvd is set to output Bitstream and then doublecheck you are selecting the DTS track on the actual dvd disc (Audio/Language selection). The amp should be set to AUTO.
  3. Glasswalker
    Glasswalker
    Ha ah, I didn't know about the audio selection in the DVD bit (don't laugh). I shall do that.
    That would make sense actually cos I suppose it wouldn't know what sound to play.
  4. S H A D O
    S H A D O
    Mar 16, 2001
    10,301
    United Kingdom
    +1,575
    No worries, it happens more often than you´d think.
