Yamaha Dsp-ai 5.1 Upgrade to 6.1
Discussion in 'AV Receivers & Amplifiers' started by MUD, Mar 7, 2001.
Tags:
  1. MUD
    MUD
    HI
    I have yamaha dsp-AI amp is there a upgrade with out upgrading for the next new model is there a hard ware you can get for that centre rear speaker to get 6.1 sound.
    MUD
  2. Adam Barratt
    Adam Barratt
    Aug 9, 2000
    170
    16
    New Zealand
    Add-on processors are available from ADA (ADA 6.1) and SMART Devices (CS-3Xjr) that will allow pseudo EX playback from your DSP-A1 (much like the RX-V1/DSP-AX1's EX implementation, in fact).
    You will need an extra power amplifier and speaker(s) in addition to the processor.
    Adam
  3. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    The A1 itself is not upgradable though you oculd use an old DPL processor connected to the pre-outs of the rear channels.
    Switch the DPL amp to stereo for 5.1 and to DPL (rears disabled) for pseudo-Ex/Es.
  4. MUD
    MUD
    THANK GUYs for your replys. I have A centre B/W speaker could I not use a cheap prologic amp. or does it have to be prosesser and amp and is it worth the bother.
    MUD.
  5. Adam Barratt
    Adam Barratt
    Aug 9, 2000
    170
    16
    New Zealand
    You could use a cheap Pro Logic amp, but the surround channel performance of your system will be compromised. The surrounds will sound like they're being run by a cheap unit, as they will be.
    With a higher quality unit like the DSP-A1, I would use an external processor and a decent power amp.
    I don't believe there are any significant sonic advantages to an EX system unless your listening room is unusually large or you are unable to listen from the sweet spot. I have all of the hardware necessary to add pseudo-EX my DSP-A1, but having listened to other EX systems, I haven't bothered. Your mileage may vary.
    Adam
  6. Frustin
    Frustin
    this hasnt a lot to do with what you are talking about but what is a good asking price for one of these amps 2nd hand?
  7. bug
    bug
    About£500?
  8. Frustin
    Frustin
    what so i should offer 500quid to this guy as opposed to the 650 he wants?
