Yamaha DSP-A595A Cent Ch Distorted
mattyn
Hi All
I have a problem with my Yam DSP-A595A Amp in as much when I have it on P/L or DD/DTS there is severe distortion from the centre channel speaker.
I have a set of mission speakers but have swapped the centre speaker and still get the same distortion. The sound is fine through the other speakers.
I appreciate its a long shot but does anyone have any ideas please? I am assuming the amp is u/s - I have connected other speakers using the centre cable from differing channels and that is fine. - So I know the cable and speaker are ok.
Please please any ideas to dsave me from having to buy another amp!
Many thanks in advance
MAtty
Knyght_byte
well, if you've ruled out teh speakers and cable then i guess its likely to be the amp :(
you could find its worth asking a dealer if they can fix it.....depends on how much they quote....
might just be worth getting a new one if its a high quote...
unless someone else here knows what might be causing it and its easily fixable.....for your sake i hope it is :)
clayts450
I can't remember whether this model had a feature to allow you to manually tweak individual channels (I had its successor, the A5, but this was a few years back*) - may be worth just double checking that you haven't inadvertantly increased the dB level on the centre channel in the settings menu ?
(Shot in the dark, I admit...)
*(Not a dig about the age of your amp - it is still a great model).
mattyn
Thanks for your answers - I shall be investigating that this evening - right after the football!!
I will let you know what I discover!
No worries about the dig - people niggle me about age all the time!
Thanks again!
Matt
Podcast: Best Hi-Fi products of 2020, Plus Best of the Month for TV Shows & Movies
