yamaha dsp-A592 amp to toshiba 2939 tv
Discussion in 'AV Receivers & Amplifiers' started by dermot, Aug 5, 2002.
Tags:
  1. dermot
    dermot
    hello i am trying to connect a toshiba 2939db 29" tv to the yamaha dsp-a592 amp, i seem be getting no sound, not 100% sure if its connected correct or not any tips or advice.
    any help is greatly thanked for in advance, as iam totaly lost on this subject,
    regards dermot
  2. bob007
    bob007
    Are you trying to get the audio from the tv through your amp, if that is the case have a look on the rear of the tv for the audio outputs (usually labled audio out, ones coloured red and the other white)connect them up with a pair of phono leads to the rear of your amp (audio input), should have one labled tv/sat or something similar. Check your amps manual if you are unsure.
  3. dermot
    dermot
    will try this tonight when i get home, thanks dermot
  4. dermot
    dermot
    you left a reply to my message today, i now a have screen shoot on the back of my amp yamaha dspa592 but i dont see any audio input, is it audio signal tv/dbs.
    also is there any other sitting i have to etc..
    thanks alot dermot
    if you want i can send you the screen shoot.
  5. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,906
    If you have a pair of phono inputs marked TV (red and white) use them, if not any spare pair of inputs (except those marked phono) will do.
  6. dermot
    dermot
    will i hear the tv through the hi-fi
    regards dermot
  7. bob007
    bob007
    When you have connected the tv to the amp select the input on the amp with your remote, (if you have connected to the phonos labeled tv then that's what you should select with the remote, or manually on the front of the amp), the sound from the tv should then be heard through your amp.
  8. dermot
    dermot
    i connected the leads from the tv marked audio out red/yellow
    to audio signal tv/dbs on amp and switched over to that on front of amp manually and no joy. any suggustions.
    regards dermot
  9. bob007
    bob007
    Yellow is normally associated with video inputs/outputs, so i would check that you are connecting to the right outputs on the back of your tv.
  10. dermot
    dermot
    i mean white not yellow, any more ideas bob
  11. bob007
    bob007
    * If you are sure they are audio outputs (check tv manual, i had a Hitachi with audio out, they did sod all aswell)) then check the phonos going into the amp, fit to the block of terminals to the left hand side, you should have two rows going down (red/white) labeled cd/tv/sat/vcr1/vcr2/ld etc. Still no joy try....
    *Scart > 2xphonos, connect to AV1/AV2 one that's an input/output, then connect to the amp.
  12. dermot
    dermot
    you are the man bob thanks for your time and everybody else that helped.
    i put the audio leads into the vcr input on the amp and it works perfect, even throgh the tv and the dvd.
    sounds good, must mess about a bit now and see why it works....
    thanks everybody.
    i am new to this forum crack but iam impresssed with the help i got from it keep up the good work.
    regards dermot (happy camper)
