Yamaha DSP A5 Subwoofer Help needed
Discussion in 'Subwoofers' started by TwinCityWild, Sep 21, 2005.
  1. TwinCityWild
    TwinCityWild
    Hi :) really appreciate it if anyone could help me with this. Total newbie to subwoofers so before buying one i thought id read the manual on my amp and see how you go about installing one. Well having read the manual it seems to me at least that i have only one actuall connection port to connect a sub to (subwoofer out)..yet all the subs ive looked at have numerous connection ports on the back. So its kinda confusing..does that mean im limited to the subs i can use??? Im probably being pretty dumb on this :rolleyes: ..but if anyone can help me...id appreciate it big time :thumbsup:
    Phil
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    Most subs will have a single connection for the LFE in which is what you will use but many have loads of other connections too - which you won't need.
  3. TwinCityWild
    TwinCityWild
    Thanks for the help ian..much appreciated :thumbsup:
