Yamaha DSP-A5 & CD Audio
Discussion in 'AV Receivers & Amplifiers' started by darrellk, Jan 17, 2001.
Tags:
  1. darrellk
    darrellk
    Sep 20, 2000
    50
    Ltiilehampton, UK
    The Yamaha amp will only display this if it is receiving a 96Khz/24bit digital signal, which can only come from a DVD (not a CD, where the sampling frequency/bitrate is 44.1Khz/16 bit). And not from any DVD disc or player either - Only some (usually specialist music) DVD discs are coded at 96khz, and only some DVD players (including Pioneer and some recent Sonys) will output a 96khz digital signal - most, including I believe Wharfedale, will downsample such a signal to 48Khz before sending it to the digital out sockets.
    HTH,
    Darrell
  2. paulw77
    paulw77
    Nov 18, 2000
    613
    28
    Wigan
    +48
    Hi all,
    I have my Wharfedale DVD player connected to my A5 with a coaxial digital cable.
    When playing audio CDs through a digital cable (ie using the Yamaha's DAC), the Yamaha is meant to display 'PCM STEREO 96K'.
    I have tried both audio output settings on the DVD player (Bitstream and PCM).Neither displays the above message.
    Anyone have any ideas ?
